Old 09-28-2007, 11:52 PM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: p0136 Code in 2004 4runner V6
Originally Posted by EagleDriver View Post
wow, it all makes sense now!! I wish i would have asked that 3 oxygen sensors ago! Are the post cat 02 sensors interchangable? (ie, can i put my old b2s2 back in and put the new sensor over on the other side? )
Look at them closely, the PART NUMBERS are imprinted on them. If they are the same = yes
If they are different , then i would say = no
CHECK the plugs (connectors) and the wire length to see if it is the same.
I think they will interchange, but cant be 100% until TUESDAY (going away for a few days and wont be back to work until then)
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
