Thread: Fuel Grade
  #21 (permalink)
Old 09-29-2007, 12:31 PM
LifeTech's Avatar
LifeTech LifeTech is offline
Last Online: 11-09-2009 12:35 AM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
Default Re: Fuel Grade
Originally Posted by 9phil9 View Post
Ed T,
You give up too easily.
For starters going from 87 to 89 octane is a really small jump.
So even if there was some advantage, it would be small.
I used 93 octane, and saw a 1.6 mile per gallon gain, but a majority of my driving is around town, where the advantage of a higher octane would make the most difference.
Because around town your engine is under moderate load most of the time trying to get you back up to speed after stopping, the low to mid RPM torque, and horsepower are increased due to the more advanced spark timing.
This translates into spending less time in lower gears.
The reason the octane would not make much difference out on the big road is because the engine is not under the heavy load it normally sees around town.
So the computer can run the spark timing at a less aggressive advance to match the lower octane, and the decreased loading on the engine which causes spark knock.
Alot of misinformation here...Anyone know what CVT stands for?
And... What lower gear?
Learn about your hybrid a little more.... everyone is confused enough.
Also, no need for anything higher than regular.
Just enjoy the ride.
My head is spinning from all the mumbo jumbo BS here .
I'll leave this thread alone....
