Re: Worklog - Road RagE II (2007 Tundra)
So far your truck is looking awesome and is inspiring me to spend more money than I want to...
Couple questions...
Was there not a factory backup camera plug in the dash that would hookup to the factory NAV with backup camera option where you could hook into for the Alpine unit instead of using the one in the overhead? From what I have gathered from this forum, all the wiring for all accessories are pre-installed by Toyota so I would think that it would be back there???
Second, I have looked for a permanent mount GPS antenna without luck, even searching your part numbers... is this item still available?
Third, I am considering the Blackbird PMD-B200 as my navigation system for a couple reasons, double duty portable GPS and plug in to the W205 and you now have on board NAV and it also comes with factory bluetooth, plus it is about $1000 cheaper than the DVD NAV system. Did you consider this at all and if you did what made you go with the DVD NAV?
Thanks in advance...
