Originally Posted by Style67
well I haven't got my speakers yet going to order them from crutchfield. I can't decide between infinity or polk but i'm leaning towards the polks the guys at crutchfield said the i could only fit a shallow mount speaker in the rear doors is this true? Also what are some good 8" subs to put under the rear seats in the storage compartment. Isn't it tough running the new wire through the rubber boot in the doors?
Thank's Style67
Not at all. I've done it quite a few times for friends on different cars and trucks. Like I said, the worst part is taking the car apart to get to it. I have an old coat hanger that I folded in half to take the sharp ends off (so I dont poke any factory wires). I feed the hanger thru and then attach the speaker wire with some tape and pull it thru. Leave yourself some slack inside the boot to compensate for the door opening and closing. Run your speaker wires and rca patch cables down one side of the trucks kick panels and run your amps power wire down the other side.
I'm sure there is a much easier way or tool to pull the speakers wires thru, but that has always worked for me just fine.
I dont have an 05 Tundra, but I've heard they are shallow mounts in the rear. Crutchfield is usually correct with what they tell you.
Good luck
