Old 10-04-2007, 10:50 PM
Cian's Avatar
Cian Cian is offline
Cian's Photo Albums
Last Online: Today 08:14 PM
Cian is on a distinguished road.
Default Brake squeal while turning?
Hey all you enlightened truck owners -
I replaced my front brake pads with Hawk ceramics (swapped the rotors with new Brembos while I was at it) back in the middle of the summer and they were fine up to a only few weeks ago. Now the front right brake squeals but only if I'm braking INTO a turn. If I brake straight on, then they are fine - no squeals. But braking while turning - either left or right - will cause the passenger side front brakes to squeal.
I've been doing some reading here, and there is an opinion that the pad springs (those paper clip looking things twisted into a "w" ) may be the culprit. Someone mentioned they weaken over time, but are really inexpensive to replace.
So I'll head down to the dealer sometime soon and will get some replacement brake pad springs, but is there any other advice out there on what could cause this brake-squeal-only-while-braking-when-turning?
I guess I can try simply removing the pads and reinstalling them first.
Thanks gang.
2001 SR5 Access Cab 4.7V8 4x4
OEM: FJ Rims; bed-liner; alarm; running boards; all-weather mats; door sill protectors; 13WL brake caliper upgrade
TRD: color-keyed mirror covers, embroidered signature mats
OTHER: Bridgestone A/T Revos; NGK Iridium IX spark plugs; Skid Row front skid plate; Fumoto drain valve; Vibrant resonator; Magnaflow exhaust tip; Form-Fit deflector; Brembo rotors; Trfytoy window latches; Undercover tonneau; Wheelskins leather steering wheel cover
PENDING: TRD coils, Bilstein shocks; TRD Kazuma LSD; Hellwig sway bar
