10-06-2007, 11:21 PM
KE7WLF Master of Disaster
Re: p0136 Code in 2004 4runner V6
Originally Posted by EagleDriver
Okay, replaced the sensor, check engine light is out but the VSC trac/VSC off light is still on. I have disconnected the batterty to ensure the computor reset. Anyone know how to reset the VSC lights?
Clear the DTC.
(1) Using SST, connect the terminals Tc and CG of the
DLC3.
SST 09843-18040
(2) Turn the ignition switch ON.
(3) Clear DTC stored in ECU by depressing the brake
pedal 8 or more times within 5 sec. ( Just keep pumping until light flashes)
(4) Check that the ABS warning light and VSC warning
light shows the normal code.
(5) Remove the SST from the DLC3.
SST = JUMPER WIRE
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
