Old 10-07-2007, 09:54 AM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: p0136 Code in 2004 4runner V6
Originally Posted by EagleDriver View Post
please forgive my ignorace.... does jumper wire = paper clip??
That should work, just dont force it into the connector and spread the contacts in the connector.
That's why I like to use a spare piece of wire, but the paper clip should work as long as your careful. If you spread the contacts a SCAN TOOL later on may not make proper contact to read any codes, if a propblem develops.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
