  #17 (permalink)
Old 10-07-2007, 11:22 AM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: p0136 Code in 2004 4runner V6
Originally Posted by EagleDriver View Post
I did this procedure, the normal blinking sequence code came up. However, my vsc trac/vsc off lights are still turning back on as soon as i put it in drive or reverse (I failed to mention.... the vsc lights are not on at start up, only when the vehicle moves a few feet)
You have a problem.
CHECK THE CODE and let me know what it is.
Check the DTC.
(1) Using SST, connect terminals Tc and CG of DLC3.
(2) Turn the ignition switch ON.
(3) Read the DTC from the ABS warning light or VSC
warning light on the combination meter.
Ill see if I can point you in the right direction.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
