Before I get flamed for not doing a search...I already did. I found the following thread:
Recycle vs. fresh air
...which is similar, but not completely. I have an SR5, without that fancy auto-air. Here's my problem:
I've noticed that my air will not stay on "recirculating". It switches to "fresh air" automatically every 3 minutes. Below are my findings from the trip into work today:
1) Air set to recirculate, ADJUSTED the temperature 2 mins into it.
19 minutes later, it automatically switched to "fresh air"
2) Air set to recirculate, NEVER adjusted the temperature.
3 minutes later, it automatically switched to "fresh air".
3) Air set to recirculate, NEVER adjusted the temperature.
4) Air set to recirculate, NEVER adjusted the temperature.
5) Air set to recirculate, NEVER adjusted the temperature.
6) Air set to recirculate, NEVER adjusted the temperature.
7) Air set to recirculate, ADJUSTED the temperature 2 mins into it.
20 minutes later, it automatically switched to "fresh air"
In summary, if I never touched the temperature knob...it always switched to "fresh air" within 3 minutes. If I messed with the temperature, I could get ~20 minutes of recirculating air before it switched.
Is anyone else having this very annoying problem? Can this type of thing be programmed by the dealer?
Thanks in advance,
Gary
