Re: MOD: All NAV Functions All The Time without Firmware Downgrade!
WileETundra,
So when the output capacitor went out, what did the NAV do?
When you were doing the initial investigation, I think you measured various voltages between 0 and 12v. Is that correct? If so, then there really should not be any problem with 12v going to the nav.
Another mod that I was thinking about was the potentiometer. Since this circuit only uses one "fixed" resistance across it, could it not also be replaced with a resistor? All we are looking for is a fixed voltage drop every 2 seconds, so an appropriate resistor should do the job. Correct?
