  #33 (permalink)
Old 10-16-2007, 02:27 PM
Tundradrenalin's Avatar
Tundradrenalin Tundradrenalin is offline
Assistant Administrator
Last Online: Today 11:27 AM
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Default Re: CR Rates New Tundra V8 4x4 Reliability Well Below Average
This report comes days after two major strikes from GM. I don't see it as very valid. Cliffy1 has outstanding points as well. If you're rating a truck against impossible odds, then you'll get irrelavent results. I wonder if the liberal media will make a special about this on the nightly news.
However, does this "consumer" report make you not want to drive your Tundra now? doubtful.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
