Re: DIY: Oil Change w/ pics. & Reset Maintenance Required Light
Originally Posted by jimdowd
Does anyone know where i could get a 65MM wrench all i see arounf is the 65/67mm
i got a metal 65mm from napa right there in the store, the plastic 65/67 didnt do it for me, just slipped, so then i cut of the 67mm part of it and the square hole where the ratchet snaps in stripped.... found the metal one and it worked perfect.
I grind of the hooks on my skid plate so it isnt cumberson to get off.... once the bolts are off it just falls off...
2007 Tundra SR5 w/ Nav
Upgrades: 100% Stock
1989 Toyota Pickup 4WD
Upgrades: Dana 44 straight front axle conversion, dana 60 rear, about 9 inch of lift total, 35x13.5 pro comp Xterrain tires on 18in american racing wheels, Ford 5.0 efi under the hood, Kenne Bell 6 pound supercharger, msd ignition, magnaflow dual exhaust, custom cold air intake, dodge nv4500 transmission, dual transfer cases, Pioneer avic-z1 dvd/nav, jl audio zr front and rear components powered by 450/4 amp, jl audio 12 w7 powered by 1000/1 amp.
