  #32 (permalink)
Old 10-16-2007, 10:11 PM
WT's Avatar
WT WT is online now
Last Online: Today 08:26 AM
WT is a splendid one to behold. WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Default Re: DIY: All NAV Functions All The Time without Firmware Downgrade!
Originally Posted by wileetundra View Post
I don't have a rear seat DVD system in my DC so I can't test it but I plan to hack the unused video input circuit on my NAV soon to gain even more video inputs than I already have. I suspect that a pulse of once every 2 seconds should do the trick but only testing can confirm. The other option is just to flip your switch back to the factory mode, then the rear DVD will display on the front when you are parked as designed.
Yes I be very interested in hearing and seeing what pins you find that we can use to add an external DVD player so we can watch DVD on the stock nav unit. I am actually suprised there is not a wire harness from were the stock overhead dvd player location to nav unit is that allows you to watch the dvd on the nav from the stock overhead dvd player. I was going to poke around the top were the stock dvd player would be some but just have not found time to do that yet.
Well I look forward to hearing what you have in mind or what your ideas are.
