Re: MODS+DYNO Results
Looking at the stock curve, it appears as if you didn't put your foot into it enough to get a WOT reading, at least that's what the A/F ratio curve says - the stock (green) A/F ratio stays at 14.7 (closed loop) longer. This may magnify the apparent gains you were seeing from the other curves in comparison.
