  #23 (permalink)
Old 10-17-2007, 04:06 PM
Rocketsled's Avatar
Rocketsled Rocketsled is offline
Last Online: 09-13-2008 04:49 PM
Rocketsled is on a distinguished road.
Rocketsled's Photo Albums
Default Re: MODS+DYNO Results
I'm not being negative or anything, I think your gains are Great!
But I did noticed on the K&N site that the picture shows that its a "boxless design" that uses the hood to seal the top from hot engine heat, but if the hood is open on the dyno runs....then it is sucking cool air from All 360 degrees. Now with the hood closed (such as when driving) you are mostly getting air from the fender hole(I believe). With the stock filter box assembly it makes little diffference in cfm if the hood is up or down.
I wonder if that would explain the extraordinary power difference.
It would be interesting if someone does a closed hood run with the same cai
Anyway NICE gains
2007 Tundra SR5 Crewmax 4x2
5.7L Slate Metalic, Graphite Fabric
Bucket seats w/floor-shift
Bedliner with deck-rail system
