10-21-2007, 05:36 PM
Re: Nav antenna placement
I had to remove my front seats and console to put my Sirius tuner underneath it. I ran my AVN-5510 Eclipse wire under the console across the rear carpet and up behind the rear seat back and out my back slider window for now. It's just a temp set up until I can drop the rear part of the headliner and run it and the Sirius antenna wire through the rear brake light opening to the roof. Eclipse cautioned against installing their antenna inside because some window tints can cause reception problems that can retard the receivers ability to react as quickly to a directional change. I tried mine on the dash when I tested it to make sure I had everything connected properly and it didn't respond as quickly as it does with the roof as a reflector.
Larry
2004 Tundra V8 Limited Access Cab 4X4 , Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
