Old 10-21-2007, 06:35 PM
Phil0411's Avatar
Phil0411 Phil0411 is online now
Phil0411's Photo Gallery
Last Online: Today 07:54 PM
Phil0411 is on a distinguished road.
Default Re: Nav antenna placement
I don't have an 07, but on my 05 I mounted the GPS antenna UNDER the dash up close to the windshield in a spot where the was no metal above it. In the 05, there is actually a small "shelf" right there and I found out after I mounted mine there, it is exactly where they mounted the factory GPS antenna. Mine get full signal strength. If you can find a spot like that, you can at least try it before exposing on the dash or hassling with running it outside. The satellite radio is another matter though. It really needs to be outside ideally on the roof. Mine is on the roof right above the third brake light. The wire goes into the third brake light housing, above the headliner, down the pillar ... well, you get the idea. If you have the fabled combination antenna (GPS and radio combined), it goes on the roof for sure.
Phil
05 White TRD D-Cab, SR5, Limited slip, 20" TRD Enkei's with BFGoodrich G-Force TA NT, All weather guard package, factory rear privacy glass with matching front door tint, Toyota bedliner plus bed mat, Toyota/A.R.E. color keyed tonneau cover, overhead console with temp, compass and Homelink, Toyota/Gentex electrochromatic mirror, keyless, mats, TRD aluminum front skidplate, Toyota/Bazooka VSE 100 watt self-powered subwoofer, TRD stainless exhaust tip, door sill guards, Custom TRD matched pin striping with Toyota logos, painted calipers with TRD letters, TRD billet aluminum third brake light cover with true TRD letters, Pioneer AVIC D-3 GPS head unit with IP Buss controlled Pioneer XM radio tuner and iPod interface, Pac remote(maintains steering wheel controls) Polk Audio speakers DB675 two way in rear, Polk DB6750 components in front powered by a Polk C400.4 4 channel amp, seperate amped Aura Pro Bass Shakers under each front seat, Bazooka EL series 8" 100 watt self-powered subwoofer with Polk Momo driver with quick disconnect, Memphis tweeters in rear, back-up sensors (very handy), foglight mod, Sylvania Silverstars in both head and fog lights, added rear halogen back-up lighting, BellTech 6700 1" lowering shackles, Hellwig anti-sway bar, Magnaflow 14586 Stainless muffler, Wheelskins two-tone leather steering wheel cover, Ventvisors for side and rear windows, custom lower grill insert, Hoppy tailgate spring. More to come!
Very funny Scotty, now beam up my clothes!
