Originally Posted by Jessyjames
Sorry ragE. One more quick question. Did you have to remove the headliner in order to access the "High mounted stop light assembly" also known as cargo light? That way you can see the wires to hook up into the cargo light? Thats what it looks like it says on the TIS website
Any documents I've seen about that lamp say you have to unbolt it from the back and that would indeed mean dropping the headliner in some fashion. That is why I tapped the harness inside the door sill. You could also look for it in the driver's side kick panel - there is supposed to be a junction connecter in there. Either way you have to tap into the wire so the harness is as good a place as any
