Old 10-22-2007, 08:16 PM
randomwalk101 randomwalk101 is offline
randomwalk101's Photo Gallery randomwalk101's Photo Albums
Last Online: 06-04-2008 08:00 AM
randomwalk101 is on a distinguished road.
Default Re: Nav antenna placement
Originally Posted by Phil0411 View Post
I don't have an 07, but on my 05 I mounted the GPS antenna UNDER the dash up close to the windshield in a spot where the was no metal above it. In the 05, there is actually a small "shelf" right there and I found out after I mounted mine there, it is exactly where they mounted the factory GPS antenna. Mine get full signal strength. If you can find a spot like that, you can at least try it before exposing on the dash or hassling with running it outside. The satellite radio is another matter though. It really needs to be outside ideally on the roof. Mine is on the roof right above the third brake light. The wire goes into the third brake light housing, above the headliner, down the pillar ... well, you get the idea. If you have the fabled combination antenna (GPS and radio combined), it goes on the roof for sure.
Phil
Phil,
With the GPS antenna under the dash like that, won't the dash block out some signal thus lower strength than as if you were to mount it on the front dash?
