Old 10-25-2007, 04:03 PM
Comattack's Avatar
Comattack Comattack is offline
My eBay Comattack's Photo Albums
Last Online: 10-16-2008 01:45 AM
Comattack is on a distinguished road.
Default Re: if the bleeder valve is opened is bleeding required?
I've always opened the bleed valve to compress the pistons, then topped of the brake fluid. (to make up for fluid pushed out) If you do brake front an rear at the same time, topping of isn't such a bad idea.
If you keep contant pressure on the piston before you open the bleed valve, and then close the valve just before fluid competely stops flowing, no air will get in and you won't have to bleed the lines. The same is true if you are going to change fluid and bleed them anyway. You still want to keep as much air out as possible.
MUD IT!!
