  #38 (permalink)
Old 10-26-2007, 11:37 AM
9phil9 9phil9 is offline
Last Online: 09-02-2009 01:22 PM
9phil9 is on a distinguished road.
9phil9's Photo Albums
Default Re: Factory Fogs on '06 are easy
Tony,
Using your GOOD hand, jack the car up a bit in front.
Place jack stands under it, just in case.
Now lay down under it and look up into the space between the front bumper and the radiator.
Sometimes the 9006 plug on the right side falls loose and can be seen easily.
If not, then just feel up along side of the radiator support frame for the plugs.
If you have them, the addition of the fogs will be easy....and factory.
Next, open the electrical fuse and relay junction box located just above and to the right of the battery.
Look to see if the 15 amp foglight fuse is already in place, and if there are metal contacts installed for the foglight relay. (Its location is shown on the inside of the cover you removed.)
If all these are in place then all you need is a #2 Phillips screw driver to install the lights.
(Refer to previous instructions contained in this thread.)
If all this is too difficult to do with one hand, then look around for any 16 year old high school girl to do it for you.
I just talked one through it 2 weeks ago, and she did all the work.
The lights mean more to her knowing that she did it herself.
