Re: Can I put an ATV in a crewmax?
Check this out. It maybe the answer to the crewmax prayers.
Add up to 4 ft. of usable cargo space to the bed of your pickup when you're hauling your ATV with this heavy-duty extender. Load tested at 450 lbs., the carrier simply plugs into any 2" receiver. It sports a 47-1/2" wide platform to handle any load, from two wheels of your ATV to construction materials for around-the-house jobs. Adjustable height to fit nearly every make and model of truck. Sliding tabs hold fingers of ATV ramps. Durable powder-coated steel construction withstands the elements.
Weight capacity: 450 lbs.
Length: 15 inches
Width: 47-1/2 inches
Wall thickness of tubing (in inches): .128, 1/8 inch
Cabelas
Or this
2007 Tundra SR5 5.7,2WD White Crewmax
Toytec 3 Inch lift,Procomp 6066 wheels
Firestone airbags with compressor
305/55/20 Tires,Step Rails,Dash Mat
Xm Radio,Magellan roadmate 2000 Nav
Bed Extender,Carbon Fiber Dash Kit
