Re: need help replacing rear tail light assembly
Originally Posted by DwwJww
I'm also having trouble replacing the rear tail light in the lift gate. If you can help me out with this, I'd be very thankful!
Try this PDF and use steps 1-5 to get the rear door panel off and access to the lights in the door.
25 yrs with TOYOTA
