Re: 2004 Rotor replacement
No they do sit on the studs (floating rotors). At times they will get stuck due to some rust or road grime. First make sure the caliper braket is off. Take one of the lug nuts and put it back on. Turn the wheel where you can hit the inside of the rotor with a rubber mallet and it should come off. Good Luck.
