Originally Posted by daless2
A wet axle is where the axle tubes contain gear oil and the axle seals are at the ends of the axle near the wheel bearings.
A dry axle has seals between the differential and the axle tubes, preventing gear oil from going into the axle tubes.
Excellent! I thought that might be the case, but I thought pretty much all axles were the wet type so I was unsure why they'd be called that.
Thanks much!
ben
