Old 11-09-2007, 12:20 AM
outriderx outriderx is offline
Last Online: 09-26-2009 02:19 AM
outriderx is on a distinguished road.
outriderx's Photo Albums
Default Re: Common Signal Lines for the 2007 Tundra
Originally Posted by PS-RagE View Post
For all other models, again you need to use the connecter for the backup monitor.
White brings ground to the camera
Black brings switched 12v to the camera
Red is video positive
Grey is video negative
I hadn’t thought of it at the time when I did my installation, but power and ground must be on this connecter. The wires left over are blue and violet. Anyone want to take their roof console down to measure out the lines?
Blue is always on power (need to verify if it shuts off after 20 minutes)
Grey (not the grey in the video bundle of 4 wires) switched power
Violet unkown? anyone?
White w/black stripe unkown? anyone?
Can someone tell me how to verify ground? I am guessing it is on Violet or more likely White w/black stripe. I will also measure the voltage out of these wires and update this thread.
EDIT: Verified voltage on both Blue and Grey wires is 12V, regulated power for the OEM camera (5.5 - 7.05V) must come from the OEM backup monitor. I also believe the white w/black stripe is the ground since it is positioned opposite the other wires AND there is a wire (same color) in the exact same position in the harness that connects to the overhead console lights.
