Old 11-09-2007, 08:22 AM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: 2001 Toyota Echo P0141 O2 Sensor Heater Fault (Bank1 Sensor 2)
Originally Posted by integraGSR View Post
P0141? I thought that a P0141 was a "System Too Lean"? If i'm not mistaking, a P0141 IS system too lean and needs a MAF sensor. are there any drivability issues? with a p0141, you vehicle should not have the same acceleration as it used to have.
I am sorry but you are mistaken.
P0171 is system to lean. This will cause hesitations, hard start, poor mileage. (see attachment)
P0141 is
Heated Oxygen Sensor Heated Circuit
Malfunction (Bank1 Sensor2)
(see previous attachment)
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
