Re: Timing Belt and Water Pump Replacement
90 to about 100 tho. miles is the best time if it goes it will cost a whole lot more to fix all the other damage. And its best to do the water pump also with a new belt it is alot tighter then the old one so it puts more pressure on the pump bearings so most likely it will leak and you will have to tear it all down again
