Old 11-12-2007, 10:39 AM
WT's Avatar
WT WT is offline
Last Online: Today 07:10 PM
WT is a splendid one to behold. WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Default Re: Automatic Tailgate and Unlock/Lock Projects with Pics..
Originally Posted by blackgts2002 View Post
What happens if you lock the tailgate and try to open it, will the actuators burn out? my thought is that the lock just disables the handle, so it if disabled the handle, you could technically leave it locked all the time and just use the remote to open it right? Negating the locking actuator..??
also, the way you did it, can you still open by hand without hurting the actuators?
They would try to open the tailgate but wont be able to since its still locked but when I am done with my setup the only time you can open the tailgate is once the tailgate has been unlocked first so this should not be a issue and even if not the motors can handle the load since its just a short pulse your sending to the actuators not a constant voltage so they wont burn out (most actuators also have thermo circuit breakers built in to eliminate this problem).
Once I am done the tailgate will function as if it was stock just that I have some control over it via the stock keyless remote. This will not cause harm to the actuators either since there not energized at rest, so they move freely forward and backwards when needed.
Hope this answers some of your questions if not let me know....
