Old 11-15-2007, 07:36 AM
Stanton49's Avatar
Stanton49 Stanton49 is offline
Last Online: 11-09-2009 07:58 PM
Stanton49 will become famous soon enough.
Send a message via AIM to Stanton49 Stanton49's Photo Albums My eBay
Default Re: DIY: OEM Security System Install
Originally Posted by tonylop33 View Post
I did the install a few day ago. I popped out the panel where the GBS goes without removing the pocket. The wire for the GBS is attached to the pop out panel.
The reason I would not recommend popping it out is because you could damage the clip on the inside of the dash that holds the GBS in place. At least with the floor shifter the process of removing the pocket panel is a one step and worth not damaging your vehicle.
As to installing the silver box (alarm ecu) I was able to install it with out removing the cross member.
I thought about doing it this way but the space was a little tight for my hands and a socket wrench.
