  #75 (permalink)
Old 11-16-2007, 11:54 AM
zpaul's Avatar
zpaul zpaul is offline
Last Online: Yesterday 11:36 PM
zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor.
zpaul's Photo Albums
Default Re: DIY: All NAV Functions All The Time without Firmware Downgrade!
Originally Posted by wileetundra View Post
I have successfully fed the video in through the rear camera input. It comes across in vibrant full color with no problem. I suspect that your wiring is not connected right or perhaps you are using unshielded wire which loses signal and allows interference to leak in.
My installer tapped into backup camera. The only problem I noticed that while driving the NAV works, but it does not guide you, only notifies that you arrived, and when I made the wrong turn it did not recalculated the route. Do you experience the same problem, or your nav is working fine? I did not have much time to play around with it, but those are couple things that I noticed. Any advise.
Here is my post. Video on the NAV screen from another video source!!!
Thanks a lot.
2007 Toyota Tundra CrewMax Limited 5.7L 2WD, Timberland
