  #76 (permalink)
Old 11-16-2007, 11:54 PM
wileetundra's Avatar
wileetundra wileetundra is offline
Super Genius
Last Online: 11-03-2009 11:15 AM
wileetundra is on a distinguished road.
wileetundra's Photo Albums
Default Re: DIY: All NAV Functions All The Time without Firmware Downgrade!
Originally Posted by zpaul View Post
My installer tapped into backup camera. The only problem I noticed that while driving the NAV works, but it does not guide you, only notifies that you arrived, and when I made the wrong turn it did not recalculated the route. Do you experience the same problem, or your nav is working fine? I did not have much time to play around with it, but those are couple things that I noticed. Any advise.
Here is my post. Video on the NAV screen from another video source!!!
Thanks a lot.
In order to enable the rear camera input while driving you have to feed the NAV a signal which tells it the vehicle is moving in reverse direction. The mapping software thus tries to show you backing up but it gets a little confused when you drive at the higher speeds because the gps signals do not match the dead reckoning it is trying to calculate based on your speed pulse and reported direction of travel. So I found that the map scrolls very poorly when I enable the rear camera feed while driving forward, but the map does update often enough for me to see where I am at, and usually on highway trips I am not turning often anyway. The bottom line is that when you watch a movie you shouldn't plan on using the map, and vice versa, but with my toggle switch panel I can flip it back into the factory mode briefly to update the map and get directions if needed, then flip back to the movie. I hope to make this a moot issue by enabling the second video input but I am not done with that project yet, and I really don't need it since the existing setup works very well for me.
WileETundra
view all of my 2007 Tundra mods and photos
