Re: 2008 Tie rod ends
My 06 At full lock either direction shows Tie rod end shift at the ball joint.
This IS NORMAL. The caster angle does change at full lock end.
What is your real question??
This has nothing to do with a "hard ride"
Check your tire pressure and adjust to spec. (lable on door drivers door jamb.)
Dealers rarly adjust them down to spec., as they are supposed to do at "pre-delivery inspection" !
The tires are shipped hard with higher pressure for shipping purposes so they don't "FLAT SPOT unto it is sold/delivered to customer.
Bear in mind they are low profile tires as well. And if pressure is ok ,the ride yu have is normal.
The Sport Model has a stiffer suspension if this is the model yu have.
Check your tire pressure first!!!!
LT
