Re: Clutch
Clutch life depends on how you operate the clutch. If you launch the truck gently and gradually from a stoplight by releasing the clutch slowly at low engine rpm your clutch could last as long as mine has (471,000 miles and counting). You also need to downshift early on hills to avoid lugging the enigne and clutch. You also need to keep your foot off the clutch pedal when waiting for a stoplight to turn green to prevent wear on the clutch throw out bearing.
