Old 11-26-2007, 11:51 AM
jfogz jfogz is offline
Last Online: 10-22-2009 07:33 PM
jfogz is on a distinguished road.
jfogz's Photo Albums
Default Re: Relocating rear pwer window switch???
Originally Posted by GraetWhyte View Post
I have a Ltd so I have not tried popping out my seat heat switches BUT, the dash locations where the plugs insert (in front of the shifter and the plugs and switches on each side of the stearing wheel) are KEYED. Certain switches and plugs can be relocated and others not. There is a threaded message in the TOWING section of this forum addressing the installation (with photos) of a Tekonsha brake controller in that area in front of the shifter. You will notice that the TOW/HAUL switch was able to be moved to the right side of the stearing wheel because the switch and its "dash-port" were keyed alike. Also sme plugs are just blanks and some are keyed. FYI.
GraetWhyte,
You are correct, Intitaly I wanted to move the Aux. Audio input over an put the Rear power window where that is now, but the switches are keyed Differently, so I put the rear power window switch to the right.
