Originally Posted by Dixie4x4
When you terminated these wires, did you convert them to RCA? How does one go about such a task? Do you have pics of the wire ends? Do I simply cut the rca, use the inside line as - and the shield as + and splice the two?
Pretty much. I used a suitably long cheapo RCA cable from my miscellaneous box of stereo parts and nipped off one end. The red wire (V+) goes to the center and the grey wire (V-) to the shield. Solder and heat shrink - tada!
