Re: Adjusting to the 2002 Tacoma 4X4
Hi Rob, this sounds kinda familiar to me. I actually have some quite over sized tires on mine, (285-75-16's) and they are balanced perfectly. Now, that said I know several people have had issues with theirs because they are "hub centric". There is a difference in the balancing techniques. If you do a search for "hub centric" here you'll find a wealth of info further explaining the symptoms and cures.
As far as the tire pressure, I would run at least 35psi. in them. I know Toyota recommends 26psi but that is assuming you are running the stock size tires on it. I would run what the tire mfg recommends or at the very least 35psi.
AKA..dingdong Silver 03 Taco Limited TRD 4dr. 4X4 V6 Auto Extang Tonneau, LineX Liner, 3" Toytec lift with front diff drop, rear Alcan, AAL's w/ degree shims, Procomp shocks front and rear, Locker mod, 285/75/16 Nitto's, Code alarm/remote start CA670, Putco Stainless Grill, Several CUSTOM off road pin stripes
