Originally Posted by coyote45
Has anyone tried to grease their front drive shaft. The grease fitting on the u-joint closest to the transfer case is blocked by a frame cross member.  . I hope there is " no disassembly" solution to this. Any help would be great. Thanks, Mike
There's a greese fitting made for tight places. Instead of fitting over the zerk, like a conventional one does, this one is pointed and you hold it up to (and push up against) the ball/hole on the zerk fitting on the driveshaft. You'll need a one-handed greese gun if you're alone.
