  #31 (permalink)
Old 11-30-2007, 11:50 AM
Cliffy1 Cliffy1 is offline
Last Online: 05-27-2009 11:12 AM
Cliffy1 is on a distinguished road.
Cliffy1's Photo Albums
Default Re: Finally fixed my dash rattle
Originally Posted by Jumbo Jet View Post
random,
Next pop out the cig. lighter assembly, it just pulls right out and unclip the wire harnesses. To remove the climate control you'll need to pop a few clips out of the silver instrument panel trim piece to release the on/off dial for the a/c fan. The climate control again pops out easily and then undo the wire harnesses. Once the climate control is out you will see four 10mm bolts holding the radio in place. Unscrew those bolts and the radio pulls out with a few clips and again undo the wire harnesses. Fit and finish is very tight on these trucks so be carefull not to force anything out and scratch the dash. If you follow that guideline, it should only take about 10 mins or less to get all that out. Once the radio and glove boxes are out you'll see the plastic piece perfectly.
Mark
How do you access these clips? Do you just pull the three large knobs off or is there more to it than that? I don't want to break the knobs while pulling them off.
Good stuff by the way. I had the thing apart this week and found what I thought was the rattle. The duct that rests on the metal brace to the left of the lower glove box seemed like the culprit. I'll get back in and see if I can figure this out from your pics and description.
I've moved dealers again. Hopefully this is the last one. I'm at Rosner Toyota in Fredericksburg VA. Call 540-898-7900 and ask for Steve Clifford... they will not know who "Cliffy" is.
