  #83 (permalink)
Old 12-07-2007, 03:05 PM
koschik koschik is offline
Last Online: 12-07-2007 03:06 PM
koschik is on a distinguished road.
koschik's Photo Albums
Default Re: Heater quit... sort of
Originally Posted by wizzer View Post
My 2001 Highlander heat just became quite intermittent. I have the manual temperature control version with the 3 knobs, not the automatic climate control. There is just one little place on the dial where the heat comes on full blast. It seems to move around and the heat will work for a while then stop. Then I adjust the knob around and find the hot spot and the heat works fine for a while. Except that it is full on. The fan works fine and the control for where the heat is directed also seems fine.
Anyone with experience with this? Is there a part I can replace? Does the dash panel around the heater radio, etc remove easily? And if so how? Anyone know of a reasonably priced source for any parts that I might need?
Thanks
I don't have a solution for you but have exactly the same problem on a 2002 Highlander and the dealer recommended a very expensive solution of replacing the entire heating control unit.
Did you ever get yours rectified economically?
