Old 12-10-2007, 12:51 AM
Hi Volt's Avatar
Hi Volt Hi Volt is offline
Hi Volt's Photo Albums
Last Online: Yesterday 10:19 PM
Hi Volt is on a distinguished road.
Default Re: Air intake Question
Originally Posted by v6er View Post
Helix is a total waist of money. and as for the FIPK, I had one and it ruined my MAF sensor, the oil you put on it ruins the MAF. I did enjoy it while it lasted though. better throttle response and sounded pretty cool too. Ofcourse if you go extremely easy on the oil I bet you could get away with it.
I will agree the Helix is a waste of money. However the oil on a K+N type filter does not ruin the MAF. A fine coating can form, but is easily cleaned off. A properly oiled K+N filter for example will not harm the MAF, been running one for 200,000 mi, serviced every 50,000 and still have the original MAF. I clean the MAF every 20,000 mi with MAF cleaner spray available at the local auto parts store (takes about 5 min to do, real easy). There are a number of posts on cleaning a MAF. An over-oiled filter can cause grief as the MAF will get coated quickly and not work properly, but is is easily cleaned as mentioned. The trick is to carefully follow the oiling instructions that come with the filter, more is not better in this case.
The stock intake is good, however has a restriction that is easily fixed see the post on the "Engine and Drivetrain" forum called "Stock Airflow Numbers and Mod".
