Old 12-12-2007, 03:01 PM
GGWOODY's Avatar
GGWOODY GGWOODY is offline
Kibble Wrangler
Last Online: Yesterday 09:31 PM
GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One.
GGWOODY's Photo Albums
Default Re: Coil-over vs. spacer lift
Originally Posted by DevinSixtySeven View Post
Yes no and sorta .
Coilovers alone only get you lift, just like a spacer...but the "spacer" on the coilover is a threaded collar, so you can choose the ride height you want.
The benefit of a coilover alone is (usually) much better valving and a higher spring rate, which you'll need offroad and hauling stuff. If you never plan to do either, get a coil rate similar to stock or risk running too stiff, which does damage your truck in the long run.
Neither spacer or coilover alone will change the amount of travel you have, but if both use stock length shocks, you will lose extension travel for compression travel and the truck will feel like a ton of bricks over every bump.
The beauty of the Camburg kit (and the Chaos arm, as modeled by Woody ) is the arm allows more suspension travel, and the coilover has a longer shaft so you can actually use that travel and your ride will be effectively like stock, assuming you use a similar spring rate.
Camburg does rebadge a SAW, but they use an internal limiting block on the long coilovers, they do have a pretty trick mounting adapter, and you'd have to ask if they revalve or just use stock SAW valving...but it's not quite just a rebadge and markup, you do get a few things from Camburg. The adapter on its own is pretty nice, and IIRC if you get the kit you also get a set of Dirtbagz to protect the new shafts.
And definitely look at Woody's threads about his kit . Go for the whole kit from Burg, the arms and the coilovers. You won't be disappointed. Or, go Chaos and SAW or Donahoe...either way, same result and great performance.
-Sean
I was hopin' you'd chime in on this one, sine I'm not the most schooled on my own setup! Sean, the almighty guru of toyota offroad suspension.
I didn't know that there was actual difference between the camburg and the SAW coilover...my bad
One other thing mhagger...This setup does great on washboards, gravel, ruts, creak bottoms, and dicey pastures. I put the suspension through the paces...not to mention while towing 10,000Lbs through hairy terrain. It really absorbsdrops in terrain and potholes at high speeds...I used to fly through terraced pastures at 30-45 mph with no problem, also used to drive off the back of levies and dams....every time, this suspension really kept me very confident that the hulking weight of this truck wasn't going to bottom out the suspension, and there was really no bump-steer either.
Want to know what's ironic? My Polish grandparents who were captured during the Warsaw Uprising.
Grandmother was enslaved in a German concentration camp and forced to make artillery shells for the 3rd Reich. Grandfather was in German and Soviet POW camps...ending up in Siberia. After WWII, they moved to the USA to be free, but Obama has turned it into the USSA...Grandaddy is rolling in his grave.
CBTMA Member
