Originally Posted by daless2
Just swapping the existing relay with a DRL relay will not enable the DRL on the Tundra.
However, if you Have DRL and do not want it, you can swap your exisiting DRL Relay for a Non-DRL relay and that will diable the DRL system.
I think this causes some confusion. I know it did to me at first too.
Have a great night.
Frank
I have DRL's but Im cheap and I dont want to buy the non-DRL relay. From your diagrams Im thinking I can snip the gray wire on pin5 from J29 and the DRL's will turn off but the blinkers will still work? or is this the common ground wire and the relay will not work at all if I snip the gray wire? thanks
