  #27 (permalink)
Old 12-19-2007, 04:14 PM
SGull's Avatar
SGull SGull is offline
Last Online: 11-22-2009 12:43 AM
SGull is on a distinguished road.
SGull's Photo Albums
Default Re: DIY: How-To-Enable DRL – 2007 Tundra
Originally Posted by jacksprat View Post
I have DRL's but Im cheap and I dont want to buy the non-DRL relay. From your diagrams Im thinking I can snip the gray wire on pin5 from J29 and the DRL's will turn off but the blinkers will still work? or is this the common ground wire and the relay will not work at all if I snip the gray wire? thanks
Really, how cheap are you??
I've got a NON DRL relay sitting around, not doing me any good,
(Suppose you cut the wrong wire and damage your ECU?)
PM me if you are interested, I'll let it go cheap.
2007 Tundra DblCab Limited Salsa Red Pearl
SNUG TOP SL, BED RUG, VAIS TECH. IPOD CONTROLLER, DU-HA REAR UNDER SEAT STORAGE BOX, TRD EXHAUST, TRD ANTI SWAY BAR, BILLET GRILL, 2.5" FRONT LIFT, NAVI, XM, SONAR, 20" WHEELS, RUNNING BOARDS, PIAA DRIVING LIGHTS,DRL ENABLED
2005 Tundra Double Cab SR5 TRD 4x2, Phantom Gray Pearl, SOLD
Magnaflow, TRD wheels chromed,VSE sub, side badges removed, Line-X, Onki Nerf Board, 3rd Eye rear sonar System
2004 Highlander Limited 2 wd, Salsa Red
2000 Access Cab SR-5 4x2 -SOLD
