12-30-2007, 10:30 AM
KE7WLF Master of Disaster
Re: 2000 Sienna dashboard removal
Originally Posted by 00SiennaXLE
do you have the entire PDF of the dashboard dissasseble? I clicked on the one above but only got 3 pages.
Also, I'm trying to add a bigger center console to my sienna. To give you an idea, I want to build a center console that acts as an armrest and connects fully with the dasboard itself, just like in a regular sedan or suv. what is your thought on doing this? I would have to get ride of the radio, but that's no problem, I'm buying and all-in-one ac/heater/radio/nav unit that will go where the current heater/ac control unit is.
The above PDF is only 3 pages. It is for removal of instrument cluster. The attached PDF is only 1 page for dissasembly. That's all Toyota has in the manual.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
