Old 12-30-2007, 04:33 PM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: Sienna sliding door problem
Originally Posted by amanhome View Post
Hi, I've used the reset several times and cleared my problem. Now that won't work the door closes but won't open. I'm guessing its the ECU. I've had the motor out and cleaned all the plastic sheathing that pealed off and got stuck in the cabel shield. My question is where is the ECU?
It is here. (see attachment)
The optical sensor circuit in the ECU is usually what goes bad.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
