Originally Posted by keez315
Hi guys, just wondering if the 99 solara V6 has a non-interference engine, the dealer nearby told me it us, wanted to check here though. How hard is the job to do? How long? What is needed to buy? Thanks
Changing the timing belt can be a little tricky and time consuming if its your 1st time and there is not much room to work since it sits so close to the wheel well. Recommend taking it to a mechanic. They idler pully should be inspected as well as the cam seals. I also recommend the water pump be replaced every 2nd timing belt repalcement (ie ~120K miles, ~240K miles, etc) as preventative maintenance. Its also a good time to replace the drive belts since they have to be removed anyway to replace the timing belt.
