Old 01-07-2008, 11:14 PM
2XOverhead's Avatar
2XOverhead 2XOverhead is offline
Moderator
Last Online: 11-18-2009 11:10 PM
2XOverhead will become famous soon enough. 2XOverhead will become famous soon enough.
2XOverhead's Photo Albums
Default Re: DIY: ATF Flush, With Pics.
Originally Posted by THarms View Post
the torque converter (TC) issue is true, but with the amount of fluid you pump through the system to do the flush there should be very little left in the TC....
The way I figure it is, unless you have a machine, you can't really expect to completely flush the system. The point is to get out the old stuff as much as possible. As mentioned, I bought the truck used, so I wanted to be certain that the tranny had relatively all new fluid.
All in all, it's better than not doing it. And, BTW, the tranny is shifting smoother, esp. first to second, and no more occasional high rev. in first.
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
