  #128 (permalink)
Old 01-10-2008, 04:16 PM
stuball stuball is offline
Last Online: Today 12:38 AM
stuball is a name known to all. stuball is a name known to all. stuball is a name known to all. stuball is a name known to all. stuball is a name known to all. stuball is a name known to all. stuball is a name known to all.
stuball's Photo Albums
Default Re: Possible Tundra Bed Bounce CURE FOUND
Originally Posted by TundraBay View Post
Air
Bags?
I had thought air bags might be a fix, but having experienced the rough ride on worn-out sections of concrete slab roads, I don't know if it would help fix the problem or not. I had Air Lift bags on my other truck for towing and will be installing the same on my Tundra, but am not sure it will check the harmonic bounce. I do find the Tundra does very well over bumps and potholes in the road but the harmonics that come from concrete slab roads that have been allowed to deteriorate to stepping stones is a problem.
Fortunately for me I don't live in an area with those kind of road conditions. However, if I did live in such an area I would be seriously considering changing my method of commuting....I would buy a new Tundra and take the backroads to work.
Stuball
2008 CrewMax Limited 2WD, Salsa Red Pearl w/Biege Int., 5.7 Eng., Moonroof, Nav/Cam, XM Radio, Remote Start, Running Brds with Foot Lamps, Woodgrain Trim, Billet Grill, 3M protection, Weathertechs, Bedrug, A.R.E. LSII Tonneau Cover, Air Lift suspension and using Amsoil.
