01-11-2008, 05:09 PM
Assistant Administrator
Re: Carolla 2005 LE, battery
Originally Posted by Easy_driver
Hello All,
my toyota carolla le 2005, has a dead battery (original) Delphi Freedom maintenance free.
I don't drive that much, that is why it died.
is there a battery that will keep the charge for a long time? I live in Queens, NY & I park in an open air car port.
i read "optima yellowtop" is good, which model would be good for my car?
also i took the battery out of the car. will this damage the car if does not have a battery installed?
I'm not knowledgeable about these things. i would appreciate your help.
thanks in advance.
b
Unless you are running some really heavy duty electronics like a half-dozen zillion-watt amps pushing 24-in woofers, you can probably get away with an Optima Red top. The Red top costs a little less and has a 3-year warranty vs. a 1-year for the Yellow top.
The advantage of the Yellow top is it puts out a lot more amps than the Red, but if your Corolla is just your basic transportation, the Red should do you fine.
__________________________________________________ Salty Dog It's all a bunch of tree-hugging hippie crap. __________________________________________________ Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Kenwood KCA-BT200 Bluetooth Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog and a New Puppy Who is not much of a Deterrent __________________________________________________
